hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
davexyz
Jun 10, 2013Aspirant
Good job I checked
Reboot with volume check
Volume check completed, 7 hours later (8.1TB)
Downloaded logs from unit looked at mounts.log
gives "/dev/c/c on /c type ext4"
So at long last the unit is in the state it should have been in upon release.
Thanks Jan
1) for the initial solution to format in ext3 which allowed full use and 2)for a time and data storage saving solution for ext4 useage without a factory reset.
now for the other units
By the way if usb drives are attached it will move these up one ie USB_HDD_1 becomes USB_HDD_2 so unplug before you do this
or if your usb name has changed , unplug, ssh into box, edit storage.conf which is in /etc/frontview/usb
remove all settings and save file,plug usb drive back in
Thanks Jan
