hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
f1arp72
Jun 19, 2013Aspirant
Hi. I have a quick question which hopefully someone can clarify. In order to fix this 80% full issue, I installed 5.3.8-T20 and rebooted. The dashboard clearly said I was running 5.3.8-T20. I then, as I believe is required, did a factory reset. During the factory reset, the unit said "Downloading FW", then "Updating FW". Now, after the reset the firmware simply says 5.3.8. The T20 has disappeared.
Has the factory reset replaced the T20 version with an older version ? Will this have fixed the 80% issue. A friend of mine was having this problem, updated to T20, factory reset his unit and his dashboard STILL says 5.3.8-T20. Why has mine "downgraded"? (Note, the fix didn't work on his unit until he factory reset the unit. Simply istalling the firmware didn't work).
Do you think if I simply reinstalled the T20 version now (having already reset unit and without any data copied to it), it will still fix thie issue.
I'm so annoyed the T20 has gone. Why !! :(
