hauser1
Dec 07, 2012Aspirant
NV+ V2 stalling when 80%+ full (20047616)
i've recently purchased one of the Netgear ReadyNAS NV+ V2 units and have become very unhappy with it. it started out ok and could copy files to it at good rate, now that the unit is over 80% full i'v...
f1arp72
Jun 20, 2013Aspirant
Thanksk for your reply. I guessed that was the situation after I noticed 5.3.8 was released on 24th May after the date of the T20 beta. I wasn't aware that a factory reset goes and fetched the latest firmware. I would of though it used the firmware on the installed on the unit.
Just another quick question. I initially have 2 x 4TB drives in the unit. Now the sync has completed (using XRaid2), it says I have 2.65TB or 2.70TB free. I'm pretty sure when I bought the unit which was running on 5.3.6 firmware, after initial sync I had the full 2.70TB free. What's happened to the extra 50GB. Windows 7 even shows a small blue bar showing the used space which is why i noticed it. Is this normal? As mentioned, I'm 99% certain i didn't lose 50GB when I originally set up the NAS out the box.
Any comments would be appreciated.
Many thanks
Many thanks
