kalpsr
Nov 22, 2014Aspirant
NV+ V2 Volume C: RAID Level X2, Not redundant
Sir, I am using a NV+ V2 with radiator version 5.3.9 and 4x2 tb Seagate hdds. I changed the 4th Hdd with same model sometime ago as it was giving smart errors. Today after booting up there was ti...
mdgm-ntgr
Nov 22, 2014NETGEAR Employee Retired
You may wish to contact our support team.
We have some paid options for looking into situations like these to see what can be done.
If a disk is failing you shouldn't remove then re-insert it. You should remove it and get a new disk.
But, you should maintain regular backups of important data. Important data should never be stored on just the one device.
