Jebross
Jan 06, 2016Aspirant
NV+ vers1, not booting, LED 1&3, cannot access boot menu #26278806
Current firmware was 4.1.14 and the device was working without a hiccup until one day when I got a new UPS and decided to hook them up via USB. Nothing was recognized upon plugging in the UPS so I shutdown the NAS figuring it might only recognize the UPS on cold start.
Instead of starting, the blue power light flashed for just over 5 seconds and then the LEDs for Drive #1 and #3 came on. The LCD does nothing and other than the fan running full tilt the machine sits idle. Completely unresponsive and requires the power to be unplugged to shut it off.
Checked the error codes - apparently I need to restore the OS from USB using the image I downloaded from the NetGear website.
However, I cannot get into the boot menu.
When I follow the instructions and turn on the unit by pressing and holding the power button, after about 7 seconds the machine just does unresponsive with LED #1 and #3 lit.
Tried again with all drives (only using two at the moment) removed. Exact same thing.
Am I doing something wrong? Or is this fried? Something I can fix? Can I get my data?
- mdgm-ntgrNETGEAR Employee Retired
The boot menu does not need to be working to run USB Boot Recovery: Unofficial ReadyNAS USB Recovery Guide for Sparc-based Systems
- JebrossAspirant
Thanks for the quick reply. The instructions in the unofficial guide link provided (thank you, btw, the links provided on the Net Gear support pages are all dead links) match what I was trying to do, holding down the power button when starting the NAS. I did not get the hard drive LEDs blinking at 5 second intervals - all I got was a steady drive 1 and 3 LED.
I am not sure how else to trigger the USB boot restore....
Have you tried plugging the NAS directly into the wall outlet and using a different power cable to see if either of those makes any difference?
