JOlesen's avatar
JOlesen
NV+ video streaming problem
I just nought myself an NV+ NAS.
I'm surprised that its so noisy :(
Don't know where to put it, you can hear the noisy allover the house :( :(
I have a probkem when streaming videos to my samsung tv.
It stops after 20 minutes, then I can start it again and forward to where it stopped, and then again it stops after 20 minutes.
Why does it do that???
  • StephenB's avatar
    Normally the fan starts up loud, and then gets quiet. Once it quiets, I can hear it in the same room, but not throughout the house.
    Frontview (health) shows you the fan speeds and disk temperatures. You should probably post them - if the fan never slows down, then you might have a hardware issue in the chassis.
  • No help here???
    Really annoying that the streaming stops after 20 minuts...
    And not really useful.
  • +1, except mine is a duo, between 10-30 minutes it stops and I have to come back and get to where I was.
  • It would be fantastic if someone from netgear would comment on this!
    Plastic fantastic!
    Lots of fine specifications, but nothing works the way it should.
    I have also tried to get the iTunes server to work, without luck.
  • I went through some of the UpnP logs from my Duo, it's showing the following:
    [2011/11/19 08:57:47] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/19 08:59:36] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/19 08:59:51] upnphttp.c:958: warn: HTTP Connection closed unexpectedly
    [2011/11/20 09:26:24] upnphttp.c:953: error: recv (state0): Connection reset by peer
    Again, happens every 20-30 minutes or so. The TV firmware has not changed, the only thing that has changed was the .18 update on my duo.
  • Unsure if any of these are related or not, but maybe the Jedi's can make some sense out of it.
    [2011/11/05 18:08:32] minissdp.c:331: error: sendto(udp_notify=10, 192.168.0.122): Invalid argument
    [2011/11/05 18:08:34] minidlna.c:153: warn: received signal 15, good-bye
    [2011/11/05 18:08:43] minidlna.c:896: warn: Starting ReadyDLNA version 1.0.22.
    [2011/11/05 18:08:43] minidlna.c:991: warn: HTTP listening on port 8200
    [2011/11/06 18:27:47] minidlna.c:153: warn: received signal 15, good-bye
    [2011/11/06 18:29:03] minidlna.c:896: warn: Starting ReadyDLNA version 1.0.22.
    [2011/11/06 18:29:03] minidlna.c:991: warn: HTTP listening on port 8200
    [2011/11/08 17:24:20] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/09 18:39:17] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/12 17:08:32] minidlna.c:153: warn: received signal 15, good-bye
    [2011/11/12 17:08:41] minidlna.c:896: warn: Starting ReadyDLNA version 1.0.22.
    [2011/11/12 17:08:41] minidlna.c:991: warn: HTTP listening on port 8200
    [2011/11/12 19:05:47] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/13 16:02:56] upnphttp.c:953: error: recv (state0): Connection reset by peer
    [2011/11/14 22:12:30] minidlna.c:153: warn: received signal 15, good-bye
  • Hi
    might not be related, but have you tried the 'no smb disconnect' addon? Could be this.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    d14blo, UPnP-AV/DLNA and SMB are two separate things. Unless SMB/CIFS is being used there is no point to using the add-on you refer to.
    Would suggest opening tech support case.
ProSupport for Business
