fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
mdgm-ntgr
May 06, 2013NETGEAR Employee Retired
What happens if you power down, remove disks (label order), insert a spare disk (must not be fom your array) and do a factory default?
