fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
mdgm-ntgr
Jul 08, 2014NETGEAR Employee Retired
Yes. This suggestion was to confirm where the problem is.
If you still get the error then perhaps try the 4.1.8 USB Flash Recovery image. 4.1.8 is a bit smaller. If there is a problem with e.g. lots of bad blocks on your internal flash, 4.1.8 may fit where newer firmware won't.
