fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
zenandjuice
Jul 11, 2014Aspirant
I'm about to do that.
I was able to put in a spare disk, do an OS re-install, and that worked. I updated the firmware to the latest 4.1.13, and restarted.
I shut it down, put in the original disks, and got the Bad Firmware error.
I'll do a full factory reset now.
