fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
mdgm-ntgr
Jul 11, 2014NETGEAR Employee Retired
Could be a bad disk or a bad slot.
Check the disks e.g. using SeaTools if SeaGate disks.
