fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
zenandjuice
Jul 22, 2014Aspirant
It's curious. If I put in a different drive, and do a factory reset, everything works.
Inserting the old RAID causes the error. Even if I boot it with only one drive, I get that error. I've even tried booting it with only one drive at a time... the likelyhood of all 4 drives going bad at once is very low, and the NAS does work with another single drive in the same slots.
Any other ideas? Would there be any chance of data recovery via tech mode, or via TFTP?
Thanks again,
Chris
Thanks again,
Chris
