fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
arjoseph1
Jul 22, 2014Tutor
Yes I also recommend that you contact support because the problem could be related to corrupted raid superblocks. Make sure that you always keep a backup of your data.
