fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE: ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue ...
zenandjuice
Aug 08, 2014Aspirant
mdgm, i want to thank you for your help. support was able to connect remotely via Tech mode and do an OS re-install.
I"m backing up all my data now. :-)
Thanks again, I really appreciate it.
-chris
-chris
