fima
May 06, 2013Follower
NV+ won't boot - firmware error - USB recovery not working
What HAPPENED BEFORE:
ReadyNAS NV+ system would intermittently reset (once every 5 to 15 minutes). To try to correct the issue it was updated to RAIDiator-V4.1.10. System continued the reset issue after the update. All hard drives were replaced with new drives.
What is HAPPENING NOW:
After welcome, system says Booting, Please wait... (no drive LEDs are on) stays in this mode for about 90 sec.
Then the fan quiets down and the LCD screen says:
Booting... (for about 10 seconds), then on the second line it says:
ERR: Bad firmwar
then,
LED 1 and 2 blink, then all four LEDs blink, then the sequence repeats.
I downloaded the image file: ReadyNAS_USB_Flash_Recovery-4.1.10.img
I wrote it to three different USB sticks using NTRawrite in Windows CMD mode
All writes were successfully verified.
I inserted each USB stick into the NV+ front USB slot (rear slots are empty) and tried the following boot procedures.
Powered on NV+ while holding the Backup button. The LCD showed:
Boot Diag
Please wait...
then,
Booting... (fan slowed) for a few seconds, then back to:
ERR: Bad firmwar
When I hold the Backup button a while longer during power up, NV+ displays:
User Diag
Please wait... (for about 60 secs)
then, back to Booting..., ERR: Bad firmwar
When I just use the Power button and hold it for 20 secs for USB boot, the screen displays
Bios info
USB Init (I can see the USB key flashing indicating the NV+ is accessing it)
then,
Welcome, then,
Booting
Please wait... (for 90 secs)
then,
Booting...
ERR: Bad firmwar (alternating 1&2 and all four LEDs)
I'm totally lost as to how to proceed...
>>>>> PLEASE HELP ! <<<<<<< :(
ERR: Bad firmwar
then,
Boot Diag
Please wait...
then,
ERR: Bad firmwar
User Diag
Bios info
then,
Welcome, then,
Booting
then,
Booting...
- zenandjuiceAspirantmdgm, i want to thank you for your help. support was able to connect remotely via Tech mode and do an OS re-install.
I"m backing up all my data now. :-)
Thanks again, I really appreciate it.
-chris - mdgm-ntgrNETGEAR Employee RetiredGlad they solved the problem.
Thanks for letting me know - nasdaq_techAspirantI won't create another posting as this is exactly my issue.
I have a NV+ RND4000.
Upon power:
Welcome...
Booting Please wait...
When I tried to OS reinstall:
Welcome...
Reinstalling FW Please wait...
When I tried to USB Boot:
Welcome...
(4 lights at each transition to...)
USB Boot
BIOS Info: USB Init.
The activity on the USB Stick goes out.
I'm at a loss. - zenandjuiceAspirantGo ahead and open a ticket. They were very very helpful.
