svdhoorn
Nov 21, 2019Aspirant
NV+ won't boot. ERR: Bad Firmware
Hi there! I seem to be have the exact same problem as user '@zenandjuice' here. He stated his solution as follows: "mdgm, i want to thank you for your help. support was able to connect remot...
Nov 22, 2019Guru - Experienced User
svdhoorn wrote:
This weekend I will try to rebuild my RAID using ReClaiMe and/or R-studio.
Those tools can recover data from a RAID array (even if there is damage). But they can't rebuild it.
ReclaiMe is the only option I know that supports BTRFS. That's used by the current OS-6 ReadyNAS.
But your old NAS uses EXT, so support for the BTRFS file system isn't needed. I suggest starting with R-Studio, as it is less expensive.
If you plan to purchase a current ReadyNAS, then another option is to pay support to temporarily mount your disks in the new OS-6 NAS so you can offload your data. More information on that option is here: https://kb.netgear.com/29876/ReadyNAS-Migrating-disks-from-RAIDiator-4-1-or-RAIDiator-5-3-to-ReadyNAS-OS-6
