console1
Nov 06, 2012Aspirant
NVX: paths for the shares listed below could[Case #19821175]
I upgraded one of the drives, every thing was fine, expanded fine and I was accessing all files fine till today when: Mon Nov 5 20:33:55 PST 2012 System is up. Mon Nov 5 20:33:55 PST 2012 The pa...
console1
I sent the logs.
btw at the end of dmesg.log I see:
EXT4-fs (dm-0): ext4_check_descriptors: Block bitmap for group 11136 not in group (block 0)!
EXT4-fs (dm-0): group descriptors corrupted!
at the end of the fs_check.log I see:
Error storing directory block information (inode=60723475, block=0, num=1868706): Memory allocation failed
e2fsck: aborted
***** File system check performed at Mon Nov 5 20:33:38 PST 2012 *****
fsck 1.41.14 (22-Dec-2010)
/dev/c/c: Note: if several inode or block bitmap blocks or part
of the inode table require relocation, you may wish to try
running e2fsck with the '-b 32768' option first. The problem
may lie only with the primary block group descriptors, and
the backup block group descriptors may be OK.
/dev/c/c: Block bitmap for group 11136 is not in group. (block 0)
/dev/c/c: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
e2fsck: aborted
