console1
Nov 06, 2012Aspirant
NVX: paths for the shares listed below could[Case #19821175]
I upgraded one of the drives, every thing was fine, expanded fine and I was accessing all files fine till today when: Mon Nov 5 20:33:55 PST 2012 System is up. Mon Nov 5 20:33:55 PST 2012 The pa...
mdgm-ntgr
Nov 09, 2012NETGEAR Employee Retired
console wrote: any one from good old team still works at netgear?
I do not want port 23 to be open like this for a long time, specially if the password is the same password as other netgear products use.
If your router supports it you could have forwarded a different port to port 23 on the NAS.
console wrote:
why netgear doesn't use the same access path that ReadyNas remote uses? vs. telnet port?
NetGear does have a support tunnel that they can use. Provided that stays up they shouldn't need port forwarding setup. Though if for whatever reason that is not up if you haven't port forwarded to the NAS and give them your I.P. there would be delays.
