console1
Nov 06, 2012Aspirant
NVX: paths for the shares listed below could[Case #19821175]
I upgraded one of the drives, every thing was fine, expanded fine and I was accessing all files fine till today when: Mon Nov 5 20:33:55 PST 2012 System is up. Mon Nov 5 20:33:55 PST 2012 The pa...
console1
Nov 20, 2012Aspirant
I still like to know why this occurred, I think the last reboot when I choice to fix quota and scan at same time on a revert to (RAIDiator-x86 4.2.21) from 4.2.22 (because of broken DLNA issue)
cause this.
I have the important stuff on NV+ and that box is fine and it can rsync back to NVX, but there were bunch of stuff that probably take a month to recover and timemachine backup on NVX is not backedup but atleast non of the machines that where doing backup to NVX timemachine has failed.
On ext4 corrupted disks, some folks do force mount (ignore fsck) method, but I have not figure out how to force mount it.
the hardest route is to write a C code to clear the superblock flags. and mount -o ro and see what is there.
there is also the trick to rewrite the superblock by initing it and let the new e2fsk run find inodes and jam them in lost+found
Mon Nov 5 19:06:30 PST 2012 Volume scan failed to run properly.
Mon Nov 5 00:32:47 PST 2012 Powering off device
Mon Nov 5 00:32:47 PST 2012 Please close this browser session and use RAIDar to reconnect to the device after it is powered back on. System powering off...
Sun Nov 4 18:36:55 PST 2012 Fan will be recalibrated over the next few minutes.
Sun Nov 4 18:29:56 PST 2012 ReadyDLNA media file rescan started.
Sun Nov 4 18:21:42 PST 2012 System is up.
Sun Nov 4 18:21:33 PST 2012 Your ReadyNAS device has been updated with a new firmware image. (RAIDiator-x86 4.2.21)
Sun Nov 4 18:18:54 PST 2012 Rebooting device...
Sun Nov 4 18:18:53 PST 2012 Please close this browser session and use RAIDar to reconnect to the device. System rebooting...
Sat Nov 3 09:42:46 PDT 2012 Data volume has been successfully expanded to 4624 GB.
cause this.
