Trial_Master
Apr 20, 2018Aspirant
NVX Power Timers
Is it possible to set up more than one power off/on timer per day via command line. The UI doesn’t allow.
Retired_Member
May 21, 2018The OS6 UI seems to allow flexible configuration throughout the same day. Now the question is, whether this firmware is compatible with your hardware. I'm pretty sure one of the experts will comment pretty soon.
- StephenBMay 21, 2018Guru - Experienced User
It's not. OS-6 requires a 64 bit platform, and the NVX is a 32 bit platform.
