R12
Aug 17, 2011Aspirant
Occasional Kernel Panic
All, Since I have upgraded my NV+ with four Seagate ST31000524AS Barracuda 1TB drives I get a Kernel Panic during boot-up once in about every two weeks. After a hard reset (unplugging the cable) it...
sphardy1
Aug 23, 2011Apprentice
A firmware reinstall wouldn't hurt - if the root cause is a firmware issue (eg corrupt file) then that could be a simple & quick way to overcome without affecting your data. See FAQ for instructions
Also consider temporarily disabling any addons or non-required services - this might help narrow down the cause if the issue "disappears" so that you can start re-enabling the addons one at a time
Else, you need to download your logs and search for clues which maybe you've done given you are stating the NAS experiences a Kernel Panic - or are you sure of that given this statement?
Same logs record the boot process
R12 wrote:
Are there loggings available on the NV+ that keep track the events during the booting process?
