lluisrd
Apr 05, 2019Aspirant
WNAP 320 kernel panic firmware
Hi,
I have a wnap320 that in an update (I supose). the firmware has been damaged.
I can not connect via ethernet in any way.
Neither managed by the concentrator or isolated. I have reset it a thousand times and never take any ip.
Connected by serial cable. I can access the terminal where appears the start of the antenna that ends with:
kernel panic - not syncring.....
Having no IP assigned (there is no 192.168.1.100, nor any other)
I have been uploading the firmware via telnet
with loadb command
the firmware
WNAP320_V2.1.1_firmware.tar
and others more updated with the same problem:
After three hours uploading the firmware and restarting the antenna.
the panic kernel reappears.
Help
Hello,
I solved this trouble with a doc made by RaghuHR 2019-02-11 05:21 PM
WNAP320 - Recovery Document.pdf
Many thanks.
But i need to do some more thinks.
Once the antenna firmware was recovered, I had to do a downgrade to 2.15 to be able to add it to the concentrator. And, "voila" the concentrator WC7520 has been able to add the antenna to the system
TNKS
- RaghuHRNETGEAR Expert
- lluisrdAspirant
Hello,
Many thanks.
TNKS
