lluisrd
Apr 05, 2019Aspirant
WNAP 320 kernel panic firmware
Hi,
I have a wnap320 that in an update (I supose). the firmware has been damaged. I can not connect via ethernet in any way. Neither managed by the concentrator or isolated. I have reset it a tho...
- Apr 09, 2019
Hello,
I solved this trouble with a doc made by RaghuHR 2019-02-11 05:21 PM
WNAP320 - Recovery Document.pdf
Many thanks.
But i need to do some more thinks.
Once the antenna firmware was recovered, I had to do a downgrade to 2.15 to be able to add it to the concentrator. And, "voila" the concentrator WC7520 has been able to add the antenna to the system
TNKS
DaneA
Apr 08, 2019NETGEAR Employee Retired
Hi lluisrd,
Welcome to the community! :)
What is the behavior of the LED lights of the WNAP320?
I have sent a private message to you. I'll wait for your response via private message.
DaneA
NETGEAR Community Team
RaghuHR
Apr 08, 2019NETGEAR Expert
- lluisrdApr 09, 2019Aspirant
Hello,
Many thanks.
TNKS
