franz76
Aug 01, 2015Aspirant
Occupied size by a Thin lun
Hi, I want to know how can I determine the occupied size for an instanced Thin lun on my RN104. It's possible with a command by CLI? The host is a Windows 8 and the lun was formatted on ntfs. The ...
franz76
Aug 02, 2015Aspirant
Hi Brian,
Thank you for reply.
Unfortunately, in Shares tab I don't have used space reported for iSCSI luns... (rn104 ReadyNas OS 6.2.5).
mdgm-ntgr
Aug 02, 2015NETGEAR Employee Retired
I can pass on this feature request for showing the used space by a thin LUN.
You asked whether it is possible using the CLI. You could try using the du command but do note that the figure you get may be quite inaccurate. For instance du does not account for compression.
