efalsken
Jan 25, 2012Aspirant
Odd LED Pattern on ReadyNAS X6
On my friend's RevB X6, it stopped responding to everything. Even power button. So we pulled the power. Now when it starts up, after what (should be) a normal boot, I see the Power LED [slow?] pulse f...
mdgm-ntgr
Jan 31, 2012NETGEAR Employee Retired
How long did you disconnect the power for? Could you try leaving it disconnected for 5-10 minutes?
So it looks like it's hanging on booting somewhere. Have you powered down the ReadyNAS, removed the disks (label order) and connected the disks up to a SATA port on your PC and checked them using vendor tools?
If you attempt to boot the NAS without disks does it show in RAIDar with the error message "No Disks detected" in the Info (far right) column?
Do you happen to remember what version of RAIDiator is on this unit?
