efalsken
Jan 25, 2012Aspirant
Odd LED Pattern on ReadyNAS X6
On my friend's RevB X6, it stopped responding to everything. Even power button. So we pulled the power. Now when it starts up, after what (should be) a normal boot, I see the Power LED [slow?] pulse f...
mdgm-ntgr
Jan 31, 2012NETGEAR Employee Retired
When the NAS booted fine with 3 disks, I would've then suggested ensuring you have a good backup.
Did you power off before inserting the 4th disk? The X6 does not support hot-swap.
I would not re-order the disks personally.
