efalsken
Jan 25, 2012Aspirant
Odd LED Pattern on ReadyNAS X6
On my friend's RevB X6, it stopped responding to everything. Even power button. So we pulled the power. Now when it starts up, after what (should be) a normal boot, I see the Power LED [slow?] pulse f...
mdgm-ntgr
Jan 31, 2012NETGEAR Employee Retired
You can reorder the disks, but it's not recommended to do so particularly when the array is not redundant. This is more of a problem on older firmware rather than newer firmware.
When you say the disk was clean was it unformatted? Or had you formatted it? Best to use unformatted disks (i.e. a disk where you've deleted all the partitions on it).
