wulidancing's avatar
wulidancing
ONVIF compatibility surveillance ReadyNAS Phylink 1080 bullet cam
I purchased a PhyLink 1080P bullet cam from Amazon for use with ReadyNAS surveillance.  The camera description states that it is compatible with ONVIF 2.0 systems.  The camera works, it is setup and ...
  • JohnCM_S's avatar
    May 26, 2018
    Hi wulidancing,
    Welcome to the Community!
    The camera compatibility list for ReadyNAS Surveillance has not been updated for years now so I am not sure if your camera will work with it.
    The ReadyNAS Surveillance was actually discontinued and was replaced by Milestone Arcus, which has a larger list of compatible cameras. You may check this link for more information about Milestone Arcus.
    You may also check here the list of compatible cameras for it.
ProSupport for Business
