wulidancing
May 25, 2018Aspirant
ONVIF compatibility surveillance ReadyNAS Phylink 1080 bullet cam
I purchased a PhyLink 1080P bullet cam from Amazon for use with ReadyNAS surveillance. The camera description states that it is compatible with ONVIF 2.0 systems. The camera works, it is setup and ...
- May 26, 2018
Hi wulidancing,
Welcome to the Community!
The camera compatibility list for ReadyNAS Surveillance has not been updated for years now so I am not sure if your camera will work with it.
The ReadyNAS Surveillance was actually discontinued and was replaced by Milestone Arcus, which has a larger list of compatible cameras. You may check this link for more information about Milestone Arcus.
You may also check here the list of compatible cameras for it.
JohnCM_S
May 29, 2018NETGEAR Employee Retired
Hi wulidancing,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- wulidancingJun 10, 2018Aspirant
Yes, your input helped tremendously. MilestoneArcus supports ONVIF camera and mine worked.
I would suggest that Netgear makes it more difficult for people to go down the wrong rabbit hole. I never saw anywhere that surveillance had been discontinued. I could download install and get a fair amount working but had no idea it was not well supported.
Arcus does not seem to work 'great'. Perhaps it's the camera that lends to the jerky frames and there seems to be an issue when accessing the camera from PhyLink app and the Arcus server app. Again, no idea whose problem that would be.
Thank you.
- Nov 24, 2016Retired_Member
