whuetwohl
Jun 01, 2016Aspirant
Operating System locks up post rsync to External USB drive.
Operating system version 6.5. After the weekly backup of the NAS to an externally connected (left rear USB) hard drive, the NAS stops responding and gets stuck in a loop that appears to try to ac...
whuetwohl
Jun 07, 2016Aspirant
The drive is writable on another machine.
Jun 07, 2016Guru - Experienced User
There are a variety of possibilities.
-the file system might be corrupted somehow, and needs reformatting or repair.
-the disk might be failing
-The drive might need external power to keep it running (Note NTFS performance is improved with OS 6.5, so the drive might need more power than it did before)
-there might be a bug in 6.5.
-there might be a problem with the USB controller in the chassis (perhaps least likely since front and rear ports both fail).
You might try a backup with a different disk (ideally one that has an external power socket you can use) - if that fails it would would rule out 1-3.
- whuetwohlJun 07, 2016Aspirant
Thank you for the response.
I have 3 separate drives that I use for off-site backup storage. They get rotated weekly. The problem occurs on two of the drives. When the second drive failed, I decided not to subject the third drive. I check the drives on a computer after every failure (I have to reformat them each time).
The disks are all just 1 year old. They are mounted in an external, powered, USB-connected caddy.
I am leaning toward the posibility that the NAS's O/S is at fault here. It is running the 6.5 version. Is there a way to get a clean installation of the O/S?
What can I do to resolve the issue? I have previously spent hours re-entering permissions on the shares several times and it's exhausting.
- StephenBJun 07, 2016Guru - Experienced User
It sounds like you have eliminated 1-3 already then. If the failure began when 6.5 was installed, then a hardware fault (though possible) seems unlikely.
Netgear did switch to a new NTFS package on the NAS, so if the drives are NTFS formatted, you might want to try a test with a freshly formatted drive (maybe even trying a test with ext or btrfs).
The only way I know of is a factory reset.
I know Netgear support can re-image the OS partition (at least mdgm can). But I've never seen that procedure written. (note I don't work for Netgear).
- whuetwohlJun 20, 2016Aspirant
Thanks StephenB. I have indeed reformatted the drive both at the NAS itself and at a computer in an external drive bay. The results remain the same. I am now experiencing a new issue which supercedes this one. I can not create nor edit any of the shared on the NAS. I get a database related error. I will open a new incident on that.
