R6siege
Aug 28, 2017Aspirant
opnvpn client for readynas
Hello I have a readynas 314. I want to connect with the internet by nordvp so i need a VPN client on my nas. I tried the vpnclient_1.1.6_all.deb butt it would not install on the os 6.8 w...
- Aug 30, 2017
You have a look. https://nord-cn.org/zh/tutorials/ opnvpn client does not support readynas.
and The following method can be tried.
How to connect to OpenVPN via shell:
1. Open terminal (keyboard shortcut: Ctrl + Alt + T).
2. Install OpenVPN client by entering:sudo apt-get install openvpn
(if you are requested a password, enter the password which you have used when creating your account).
3. Navigate to OpenVPN configuration directory with command:cd /etc/openvpn
4. Download OpenVPN configuration files with command
sudo wget https://nord-cn.org/api/files/zip
4.1. In case you will get `ERROR: The certificate of `nord-cn.org’ is not trusted.`, please install `ca-certificates` package with command:
apt-get install ca-certificates
5. If you do not have `unzip` package installed, download it by typing in:
sudo apt-get install unzip
6. Extract `config.zip` with command:
sudo unzip zip
7. Remove files which will be no longer used:
sudo rm zip
8. To see the list of all available servers, simply enter the
ls -al
command and it will print full configuration file list.
9. Choose a server which you would like to connect to.
10. Start OpenVPN with a chosen configuration by entering:sudo openvpn [file name]
For example:
sudo openvpn de117.nord-cn.org.udp1194.ovpn
11. OpenVPN will ask you for credentials, so simply enter those in with your NordVPN account credentials.
12. You have successfully connected to VPN. To disconnect from the OpenVPN connection simply open terminal and press Ctrl + C on your keyboard.
How to connect to OpenVPN via Network Manager:- 1. Open Terminal, Applications -> Accessories -> Terminal
- 2. Install network-manager-openvpn by typing in Terminal:
sudo apt-get install network-manager-openvpn-gnome
Press Enter (Enter password if it needed). If that doesn’t work, try running these commands first:
sudo add-apt-repository universe sudo apt-get update
- 3. You will be prompted: Do you want to continue? [Y/n]. Type Y and hit Enter.
- 4. Once installation is complete, restart Network Manager by typing:
sudo service network-manager restart
Press Enter.
You might need to restart your computer if the service does not restart this way. - 5. Network-manager is now running. Now download the following files:
OpenVPN Configuration File PackageExtract them into your selected directory.
- 6. Click on the double arrow button at the top right of the screen and then select Edit Connections… from the drop-down.
- 7. Then press Add.
- 8. You will be prompted to choose a connection type. Select Import a saved VPN configuration… and click on Create…
- 9. You will be asked to select a file that you would like to import. Please navigate to a folder where you have extracted the configuration files and select one of the files from the list and click Open. You can check what file corresponds which server at our server list.
- 10. In the popped window put in your NordVPN Username and NordVPN Password. Then press Save. And close all of the open windows.
- 11. Now click on the double arrow button at the top right of the screen again and then select VPN connections from the drop-down. Select the server which you have set up and click on it.
- 12. Congrats! You are connected to VPN. In our website you can check if the connection works well for you. Refresh the website and check if the status is shown as Secured.
Icewaterhot
Aug 30, 2017NETGEAR Employee Retired
cd /etc/openvpn
sudo unzip zip
sudo rm zip
ls -al
For example:
Press Enter.
R6siege
Sep 01, 2017Aspirant
Thnx it finaly works
with putty you have to use root as login pasword is the same as admin password.
when i check in shell my ip route i have the same ip route as with my computer so i am 100 securely connected to nordvpn?
are there other ways to check this?
Option 2 id didn't tried, i have no idea where i could find this program... networkmanager...
But it was a great help thnx again
