LongTimer
Mar 23, 2018Aspirant
Original Infrant ReadyNAS NV powers up but not responding
After a recent power outage, our original Infrant NV seems to turn on but will not respond. It was populated with 3 WD 3 TB drives and has been that way for 6 or 7 years working perfectly. So prefe...
- Apr 01, 2018
Well I've been rooting around the rabbit hole for a while now and I'm finally up for air. I was trying to use System Rescue CD but that was a dead end as it was too hard for me to add the necessary software without apt-get. I switched and set up a live persistent USB with Mint 18 and was able to access the files. As we speak they are being transfered to another drive. The USB was very easy to setup using Windows software here: https://www.pendrivelinux.com/universal-usb-installer-easy-as-1-2-3/
As many here know, the key was to use "fuseext2". Not "fuse-ext2" and not "mount". For those who are reading this without seeing alot of other info the SPARC versions of the ReadyNAS NV with version 4.x firmware use a non-standard 16k block size so fuseext2 is the only one that will play nice-ish. I still could not access the mounting with any GUI applications on Mint and it would lock up the LV if I tried. With my level of knowledge the only way out at that point was a reboot.The following instructions posted elsewhere will work. Just use the right mounter fuseext2 and do not add a dash. That was a huge time waster for me.
(1) sudo su (2) apt-get install fuseext2 (3) apt-get install lvm2 (4) modprobe fuse (5) vgscan (6) vgchange -ay c (7) fuseext2 -o ro /dev/c/c /mnt (7) fuseext2 -o ro -o sync_read /dev/c/c /mnt That’s it!!! You can now see the mounted files in the /mnt directory
While the clues were there, it took a long time for me to put them together. On an unsuccessful mount, Mint gives some advice to check the dmesg using
Code: dmesg | tail where I found this:
Code: EXT3-fs (dm-3): error: bad blocksize 16384
Googling the message found someone with the same issue and that fuseext2 must be used to accommodate the nonstandard block size. With that change, it was off to the races and plodding through authoring the proper rsync and find commands to get what I wanted.
I still like the tool set on the SytemRescueCD and while it can be done, I don't think I am at the level to add the software required to this live CD. It is a shame that it is not easier as there are always new (or old) tools that come along a person might need or want when troubleshooting.
Thank you very much for the time you spent considering my challenge. Just knowing there are knowledgeable people like you willing to help lowered the anxiety greatly.
mdgm-ntgr
Mar 23, 2018NETGEAR Employee Retired
3TB disks aren't supported by the NV so I'd be surprised if you're using those.
This doesn't look like a situation an OS Re-install would help with. An OS Re-install will reset some network settings (ones that may lock you out of the system if configured incorrectly) and the admin password and extract the OS over itself. It won't magically fix a bad disk.
If your backup is not up to date you may wish to contact support. There would be costs involved with this.
You can send me your logs if you like (see the Sending Logs link in my sig), but it does sound like contacting support would be best in your situation.
If your data's important to you then you really should backup that data regularly in future, especially if the primary copy of the data is on a very, very old device.
Troubleshooting would be the same as for the NV+ (v1) except for the lack of a display on the front. So like the Duo you'd have to rely on seeing the LED pattern for using the boot menu etc.
The Duo/NV+ (v1) boot menu is very different to the menu for the v2 so don't look at the wrong boot menu by mistake.
It's possible disk cloning may be needed to attempt to recover data, but the logs would need to be reviewed before one could jump to that conclusion.
LongTimer
You are right. It has 3 of 2.0 TB Western Digital WD20EARS. Late night when I was typing and I can't seem to edit the message to correct.
Logs sent.
Last backup is from April 2016.
I am thinking maybe of pulling Drive 3 and tyring to restart. I really don't like having to pull the plug when it locks up.
I will wait for your comments/feedback before taking any further action.
- SandsharkMar 24, 2018Sensei
You need better information befoe pulling a drive and re-booting. The re-allocated sector count on Drive 3 is nowhere near the critical level. The ATA error on drive (??) is a lot more troublesome. But unless you can confirm that is also on Drive 3, then you are not ready to pull any drives. If you pull the wrong one and an ATA error occus during the re-sync, all could be lost.
If the info you need isn't in the logs, then testing all the drives on a PC with WD Lifeguard would be a good next step. Just insure you keep the NAS power off all through the testing and you return the drives to their orignal locations.
- LongTimerMar 24, 2018Aspirant
Here is the SMART log. I believe the Peding Events Count might be a sign however I`m not sure when this count is considered high enough to be an issue.
Thank you for the suggestion to use the WD utility. I will get set up to do that. Drives are numbered and the NAS is off until I have a game plan.
***** smartctl output for hdc ***** smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green (Adv. Format) Device Model: WDC WD20EARS-00MVWB0 Serial Number: WD-WMAZ20115523 LU WWN Device Id: 5 0014ee 6002c9cbc Firmware Version: 50.0AB50 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Fri Mar 23 03:17:59 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (37200) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 255) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 12 3 Spin_Up_Time 0x0027 166 164 021 Pre-fail Always - 6666 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 96 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 014 014 000 Old_age Always - 63005 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 62 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 51 193 Load_Cycle_Count 0x0032 106 106 000 Old_age Always - 282999 194 Temperature_Celsius 0x0022 118 104 000 Old_age Always - 32 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 2 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 3 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. ***** smartctl output for hde ***** smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green (Adv. Format) Device Model: WDC WD20EARS-00MVWB0 Serial Number: WD-WCAZA2007995 LU WWN Device Id: 5 0014ee 2afd0b076 Firmware Version: 51.0AB51 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Fri Mar 23 03:17:59 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (35760) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 255) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 253 253 021 Pre-fail Always - 1125 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 22 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 1 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 056 056 000 Old_age Always - 32519 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 20 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 18 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 2319 194 Temperature_Celsius 0x0022 113 106 000 Old_age Always - 37 196 Reallocated_Event_Count 0x0032 199 199 000 Old_age Always - 1 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. ***** smartctl output for hdg ***** smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green (Adv. Format) Device Model: WDC WD20EARS-00MVWB0 Serial Number: WD-WCAZA2099151 LU WWN Device Id: 5 0014ee 2afd3ff6d Firmware Version: 51.0AB51 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Size: 512 bytes logical/physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Fri Mar 23 03:18:00 2018 PDT SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x84) Offline data collection activity was suspended by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (35760) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 255) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 1 3 Spin_Up_Time 0x0027 253 253 021 Pre-fail Always - 1166 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 39 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 10 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 014 014 000 Old_age Always - 62832 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 37 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 36 193 Load_Cycle_Count 0x0032 101 101 000 Old_age Always - 297271 194 Temperature_Celsius 0x0022 117 106 000 Old_age Always - 33 196 Reallocated_Event_Count 0x0032 190 190 000 Old_age Always - 10 197 Current_Pending_Sector 0x0032 196 196 000 Old_age Always - 1452 198 Offline_Uncorrectable 0x0030 200 198 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 140 000 Old_age Offline - 194 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. ***** smartctl output for hdi ***** smartctl 5.42 2011-10-20 r3458 [padre-linux-2.6.17.14ReadyNAS] (local build) Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net Smartctl open device: /dev/hdi failed: No such device or address- mdgm-ntgrMar 25, 2018NETGEAR Employee RetiredThe current pending sector count of hdg is huge. That disk is bad.
Are the current pending sectors on hdc recent?
