kevin_marchant
Oct 22, 2015Aspirant
OS 6.4.0 - ReadyNAS 316 - Front Panel Lights Permenantly On - Anyone else ?
Since upgrading from 6.2.4 to 6.4.0, the front panel lights on my 316 have been set to permenantly on / high brightness and the panel is unresponsive to touch input. I've tried the workaround used o...
- Oct 27, 2015
Hello kevin_marchant,
I don't see him actively answering in the community lately but you can try sending PM to him.
Or you can also try contacting support center to have them check your NAS.
JennC
Oct 23, 2015NETGEAR Employee Retired
I believe this result occurred on one of the BETA 6.4 versions.
Other than LEDs problem, are you getting any other problem after the update to 6.4.0? Can you still access the shares and the admin page?
- kevin_marchantOct 27, 2015Aspirant
Yes, other than the front panel, the box works as expected (admin, shares, timemachine).
I have two 316's purchased May '13 and Jan '15, both running 6.4.0
The front panel on the older one works fine. The problem is only with the newer one (different revision of motherboard ?)
The problem occurs everytime from a cold start.
I can reliably clear the problem on the newer one if I do a "reboot".
So yes, I'm hopeful it's not a hardware problem and as you suggest a firmware problem
Shall I contact Skywalker directly or can you ask him to PM me? He may recall I helped out with some slow file copy problems in 6.1.9
Kevin
- JennCOct 27, 2015NETGEAR Employee Retired
- xcom923Nov 20, 2015Aspirant
I wouldn't call this "solved" I have the same problem. It's clearly a firmware issue. I didn't have this problem before I updated the firmware to 6.4. But then again I didn't have it but for a day before I updated the firmware
