spiderman1
Oct 11, 2015Guide
OS 6.4 Experience on Legacy Hardware
Just for the record, here is my performance page. Seems that everything seems to be working ok.
I wonder if any of you in the community running legacy hardware with moded CPUs (i.e...
Supertramp11
Dec 06, 2015Luminary
On my PRO 6 business edition with 4 disks, cpu = 33 degrees and system = 54 degrees in an 21-22 degrees room running for 12 hrs now.
Seems like there is a difference between 6.3.5 and 6.4.0.
Equinox1
Dec 06, 2015Guide
For me, in the heavily modified machine (Q6600, 4Gb RAM, exotic fans, etc...) 45 CPU, 60 System are normal numbers... The disks run between 32-42 degrees....
The fans vary from 900 to 1500 RPMs.
On the 'stock' Pro6 I have 1-2 degrees less on average... but heavily dependent on load. When the disks start the monthly balancing, it sounds like I have the Concorde in the house... :-D
- Equinox1Dec 06, 2015Guide
Question to the Netgear guys... where is the 'system' temperature coming from? As another mentioned before, my dashboard says I have 60C degrees, but I have no real world indication of such temperature.
