spiderman1
Oct 11, 2015Guide
OS 6.4 Experience on Legacy Hardware
Just for the record, here is my performance page. Seems that everything seems to be working ok.
I wonder if any of you in the community running legacy hardware with moded CPUs (i.e...
spiderman1
Oct 12, 2015Guide
I can't give you a reason as to why you are not seeing similar details on your performance page at least a SYSTEM and CPU fan reading graphic -- if this is what you mean.
In order to fix a dead CPU fan graphic that was appearing in the OS interface, I simply added a line to my system.conf file in the sensors.d folder which fixed it. As to the other information on the performance page, it was always there.
I don't know if you should upgrade to 6.4 as of yet a I have issues with WoL. Maybe a future release will fix this problem.
Cheers.
ATCIS
Oct 12, 2015Tutor
I'd like to add to this discussion. My original post got moved to an area of the forums that I feel may not be getting the exposure I was hoping for. It's been a few days now and no one has chimed in with a solution as of yet. The thread that I am referring to can be found here: https://community.netgear.com/t5/Using-your-ReadyNAS/Fan-CPU-in-enclosure-Internal-speed-is-below-threshold-after-FW/m-p/991414#M95036
