spiderman1
Oct 11, 2015Guide
OS 6.4 Experience on Legacy Hardware
Just for the record, here is my performance page. Seems that everything seems to be working ok.
I wonder if any of you in the community running legacy hardware with moded CPUs (i.e...
viperhansa
Oct 18, 2015Virtuoso
Ok,finally i took the leap of faith and upgraded my 6.3.5 to 6.4.0...
And everything went well, just updated it from frontview.
So far everything that worked before 6.4.0 seems to work now also.
Will update if i run into something fishy.... ;-)
// hans
Supertramp11
Oct 19, 2015Luminary
Hi Hans,
Thanks for early adopting 6.4.0.
I also have a ReadyNas 6 Pro which works great with OS 6.3.5, including the fans.
How are the fans on your NAS doing after upgrading to on 6.4.0?
Thanks!!
- heliumhelOct 19, 2015Initiate
updated mine to 6.4 a few weeks ago. Seemed to go ok but when I powered down this last Friday and restarted the device (first time since upgrade completed), it now only gets as far as the "ReadyNAS" LCD display. Doesn't recognize disks being pulled out, won't access boot menu and as far as I can tell the USB recovery hasn't worked yet. I would make sure you have a good backup of your data before proceeding and understand you may end up with a brick.
- viperhansaOct 20, 2015Virtuoso
I have done several restarts and gone thru most of the functions on my 6.4.0 and so far i dont see anything that indicates a problem with my NAS.
