spiderman1
Oct 11, 2015Guide
OS 6.4 Experience on Legacy Hardware
Just for the record, here is my performance page. Seems that everything seems to be working ok.
I wonder if any of you in the community running legacy hardware with moded CPUs (i.e...
walshlink
Oct 23, 2015Luminary
Model: ReadyNAS Pro 6 (RNDP6000-200)
Upgraded CPU: Intel Xeon X3230
Memory: 4 GB
HDD: 4x Hitachi 2TB
Upgraded System Fan: Noctua NF-P12 PWM - 120mm
Upgraded CPU Fan: Noctua NF-R8 PWM - 80mm
OS: 6.4.0
CPU temp sit around 48C idle and shown in performance tab.
I have not seen any issues other than SMB shares accessed from OSX (El Capitan, 10.11.1) disconnecting after long periods of time.
Jophus
Oct 28, 2015Luminary
My Ultra 6 on 6.4.0 upgraded and works flawlessly. My RN102 2-bay ARM model will not shut down gracefully. This is affecting a number of people
It works better on legacy than the modern replacements.
- ksalnoNov 01, 2015Aspirant
I have an Ultra 6 Plus that I am ready to upgrade from 4.2.27. Can I go straight to 6.4?
Is there a more recent set of instructions? The ones I've found have links to download files but the links are broken and the instructions were written for ver 6.1. I'm looking for something more current without having to read 125 pages in that thread.
TIA
Karl
- paaljNov 22, 2015Aspirant
Hi,
I upgraded to 6.4.0 and later to 6.4.1RC1. on my RN ultra 2. I have to restart every second day or so. The "find" command is filling up my memory and swap file. After 24 hours it is about 300 tasks (50 running) of the "find" command. I did a killall and got a lot of free memory, cpu and only about 180 tasks in "top". After some hours it is building up again. Does anyone know what is going on?
br,
Paal
I installed htop and got some more info on the "find" command.
- mdgm-ntgrNov 22, 2015NETGEAR Employee Retired
TIA
Karl
Yes you can go straight to 6.4. Just need to
1. Backup your data
2. Install the PREP R4 to R6 add-on3. Install the R4 to R6 firmware image.
Links to the add-on and the R4 to R6 - 6.4.0 firmware image are in the 3rd post of this thread: https://community.netgear.com/t5/Using-your-ReadyNAS/OS6-now-works-on-x86-Legacy-WARNING-NO-NTGR-SUPPORT/td-p/897021
