ShastaCat
Sep 05, 2016Aspirant
OS 6.5.1 on RN316: Unable to modify many settings
I have two of model RN316, 6-bay, about 2-years apart in purchase dates. The first was updated from OS v6.1.4 (hereinafter called "Unit 1", which was purchased in 2014) and the newer from OS 6.4.2 (h...
mdgm-ntgr
Sep 06, 2016NETGEAR Employee Retired
Sounds like the GUI from the old firmware was cached by your web browser. You could try clearing your web browser cache, closing your web browser and reopen the web admin page and see if this helps.
If you configure the NAS to use a static I.P. address then yes you will need to manually specify the DNS server addresses.
ShastaCat
Sep 06, 2016Aspirant
Clearing cache and restarting the browsers did not show any changes. I have used both Firefox and Chrome, with no change in symptoms. However, thank you for the suggestion.
- mdgm-ntgrSep 06, 2016NETGEAR Employee Retired
Well it sounds like you didn't clear the cache properly then. The UI should show the same for both units.
- JennCSep 09, 2016NETGEAR Employee Retired
Hello ShastaCat,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,- ShastaCatSep 09, 2016Aspirant
JennC:
Thank you for your reply.
As to feeback, I would have to say the information provided did not offer much of a solution to any of the 5 issues I listed.
Issue A was resolved, as noted above. Issue B was resolved on Unit 2, but not Unit 1, which now will not re-enable at all. I have rebooted the NAS several times with no change, so this issue remains unresolved. Issue C is unresolved. All the backup attempts would fail with "Failed to copy". I tried several methods, including reverting all settings to what they had been, deleting the backup job, and then following the procedure all over again, but it still ended up with the same result (fail). Issue D is Unresolved and I could not find a good procedure explaining how to properly configure those aspects. Issue E appears to be resolved, now that I have rebooted both united several times.
I would very much like some suggestions relevant to "B", "C", or "D", As I would like to resolve those issues and be able to fully utilize those features.
Thank you again for your reply.
- StephenBSep 10, 2016Guru - Experienced User
It's difficult to have one thread with 5 problems.
The netgear time servers aren't running 20 minutes fast for me, so I am finding that odd to begin with. I think its more likely that you were never reaching them, and the hardware clock in the NAS was that far off. Perhaps make sure unit-1 can reach the internet before you try the factory reset. An OS reinstall might be worth a try.
To provide much guidance on C we'd need to see the details of the backup job configuration. If you are using the host name, perhaps try the IP address instead.
