Supertramp11
Sep 09, 2016Luminary
OS 6.5.2 still causes fan issues on the PRO 6, like OS 6.5.1 but unlike OS 6.5.0
- Sep 10, 2016
You could try
# echo 1000 > /etc/frontview/min_fan_speed_override
# systemctl restart readynasdas a temporary workaround. This forces the NAS to aim for a higher minimum fan speed of 1000 RPM which may be necessary for some fans.
This is a change you can easily reverse by removing the override file and restarting readynasd.Edit: Now that 6.6.0 is available you may wish to try that.
mdgm-ntgr
Sep 09, 2016NETGEAR Employee Retired
I think a possible fix was committed to the 6.6.0 branch but not to 6.5.2.
Supertramp11
Thanks.
I'm a bit reluctant to verify this as I understand I cannot go back to 6.5.0 once upgraded to 6.6.0. And as I shared in another thread, the PRO 6 fans work absolutely GREAT on 6.5.0.
- mdgm-ntgrSep 10, 2016NETGEAR Employee Retired
You could try
