aalexandrebeta
Jan 28, 2017Master
OS 6.6.1 fan speed
It would be interesting to have a custom mode where you can setup fan speed. And on this version fan revs are a bit too high 750 rpm would be ideal!
Jan 28, 2017Guru - Experienced User
There are some overrides you can set with ssh. Plus there is the quiet/balance/cool setting.
- aalexandrebetaJan 29, 2017Master
What overrides do you use using SSH?
"Plus there is the quiet/balance/cool setting." I know it and use it but an extra ladder could used such as custom!
- StephenBJan 29, 2017Guru - Experienced User
The is a minimum speed override. https://community.netgear.com/t5/Using-your-ReadyNAS/OS-6-5-2-still-causes-fan-issues-on-the-PRO-6-like-OS-6-5-1-but/m-p/1138003/highlight/true#M115451
