vandermerwe
Jul 05, 2013Master
OS 6 problems need subforum
Had a quick look - does not seem to be a forum to discuss OS6. I've just got a 316, and I now see why there are so many complaints - the GUI is appalling. In 2 hours I've encountered the following...
mdgm-ntgr
Jul 06, 2013NETGEAR Employee Retired
vandermerwe wrote: The failure to find the Nas was with 6.0.4.
That is an old build built months ago, I think. So it could have been fixed since then. I think the I.P. should show on the display at the front of the NAS when the display is active.
vandermerwe wrote:
What concerns me is that, if the GUI is so poor, is the unit going to alert me to problems and maintain my data reliably.
The GUI does not inspire much confidence in what it's directing.
The NAS uses md RAID with the BTRFS filesystem on top. BTRFS has some nice improvements over EXT4 which was used in the older devices including some reliability improvements.
vandermerwe wrote: I have also discovered that the facility to add a disk to an xraid2 volume and specify whether it's for volume expansion or dual redundancy is also not present.
Hopefully this feature will be added in a future release. It is a great feature in 4.2.x.
