aks-2
Oct 04, 2020Apprentice
OS6 home folder access rights reset
I am moving data from an NV+ v2 to RN214 via an external backup (USB3), as I need to reuse the drives from NV+. I have set up the shares and user home folders, and used a backup job to restore th...
- Oct 04, 2020
chown should take care of it assumoing you actually created the shares by creating the users and then either logging them in or using mkhomedir_helper. You cannot create a proper user folder by letting a backup restore create it.
Sandshark
Oct 04, 2020Sensei
