MaxxMark
Dec 18, 2017Luminary
OS6 stuck at booting / mounting btrfs
I rebooted my NAS today after it became a bit sluggish and prior to wanting to update to 6.9.1 (i'm at the latest 6.8.x version right now). After rebooting the NAS didnt come up, and the LCD disp...
- Dec 20, 2017
I'm one small step closer.
I based it off of this post: https://askubuntu.com/questions/157917/how-do-i-recover-a-btrfs-partition-that-will-not-mount
I have done a btrfsck on the system which seems to state that there ís something wrong with my volume:
root@NAS:/var/log/frontview# btrfsck -p /dev/md127 Checking filesystem on /dev/md127 UUID: d3d6c597-3eb2-4923-bb50-ee21e11dcfec checking extents [o] checking free space cache [o] checking fs roots [O] checking csums checking root refs checking quota groups Counts for qgroup id: 0/262 are different our: referenced 12925101330432 referenced compressed 12925101330432 disk: referenced 12849220059136 referenced compressed 12849220059136 diff: referenced 75881271296 referenced compressed 75881271296 our: exclusive 12925101330432 exclusive compressed 12925101330432 disk: exclusive 12849220059136 exclusive compressed 12849220059136 diff: exclusive 75881271296 exclusive compressed 75881271296 Counts for qgroup id: 0/270 are different our: referenced 1132319191040 referenced compressed 1132319191040 disk: referenced 1131488161792 referenced compressed 1131488161792 diff: referenced 831029248 referenced compressed 831029248 our: exclusive 1132319191040 exclusive compressed 1132319191040 disk: exclusive 1131488161792 exclusive compressed 1131488161792 diff: exclusive 831029248 exclusive compressed 831029248 Counts for qgroup id: 0/277 are different our: referenced 20862586880 referenced compressed 20862586880 disk: referenced 20729131008 referenced compressed 20729131008 diff: referenced 133455872 referenced compressed 133455872 our: exclusive 20862586880 exclusive compressed 20862586880 disk: exclusive 20729131008 exclusive compressed 20729131008 diff: exclusive 133455872 exclusive compressed 133455872 Counts for qgroup id: 0/278 are different our: referenced 83479613440 referenced compressed 83479613440 disk: referenced 83248349184 referenced compressed 83248349184 diff: referenced 231264256 referenced compressed 231264256 our: exclusive 83479613440 exclusive compressed 83479613440 disk: exclusive 83248349184 exclusive compressed 83248349184 diff: exclusive 231264256 exclusive compressed 231264256 Counts for qgroup id: 0/279 are different our: referenced 41265213440 referenced compressed 41265213440 disk: referenced 33458343936 referenced compressed 33458343936 diff: referenced 7806869504 referenced compressed 7806869504 our: exclusive 41265213440 exclusive compressed 41265213440 disk: exclusive 33458343936 exclusive compressed 33458343936 diff: exclusive 7806869504 exclusive compressed 7806869504 found 14220525928448 bytes used, no error found total csum bytes: 141941444 total tree bytes: 1367834624 total fs tree bytes: 827392000 total extent tree bytes: 347897856 btree space waste bytes: 251305664 file data blocks allocated: 21737524551680 referenced 14189602930688
Then I followed up with mounting the partition:
root@NAS:/mnt# mount -t btrfs -o recovery,nospace_cache,nospace_cache /dev/md127 /mnt/datadisk/ root@NAS:/mnt# cd datadisk/
root@NAS:/mnt/datadisk# ls -l total 136 drwxr-xr-x 1 root root 230 Nov 23 18:09 . drwxr-xr-x 1 root root 16 Dec 20 18:32 .. drwxrwxrwx+ 1 admin admin 1352 Nov 17 00:56 Backup drwxrwxrwx+ 1 guest guest 20 Aug 20 15:11 Documents drwxr-xr-x 1 admin admin 94 Aug 20 15:07 home drwxrwxrwx+ 1 guest guest 20 Aug 20 15:11 Music drwxrwxrwx+ 1 guest guest 38 Sep 15 17:41 Pictures drwxrwxrwx+ 1 502 dialout 170 Dec 18 18:56 Videos root@NAS:/mnt/datadisk# du -sh 13T .
root@NAS:/mnt/datadisk# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 555M 3.1G 15% / tmpfs 998M 0 998M 0% /dev/shm tmpfs 998M 3.7M 994M 1% /run tmpfs 499M 1.1M 498M 1% /run/lock tmpfs 998M 0 998M 0% /sys/fs/cgroup /dev/md127 14T 13T 701G 95% /mnt/datadiskEdit:
I've unmounted the partition and tried to mount it normally again and that worked like a charm:
root@NAS:/mnt# mount -t btrfs /dev/md127 /mnt/datadisk/ root@NAS:/mnt# cd datadisk/ root@NAS:/mnt/datadisk# ls -l total 136 drwxr-xr-x 1 root root 230 Nov 23 18:09 . drwxr-xr-x 1 root root 16 Dec 20 18:32 .. drwxrwxrwx+ 1 admin admin 1352 Nov 17 00:56 Backup drwxrwxrwx+ 1 guest guest 20 Aug 20 15:11 Documents drwxr-xr-x 1 admin admin 94 Aug 20 15:07 home drwxrwxrwx+ 1 guest guest 20 Aug 20 15:11 Music drwxrwxrwx+ 1 guest guest 38 Sep 15 17:41 Pictures drwxrwxrwx+ 1 502 dialout 170 Dec 18 18:56 Videos
root@NAS:/mnt/datadisk# df -h Filesystem Size Used Avail Use% Mounted on udev 10M 4.0K 10M 1% /dev /dev/md0 4.0G 555M 3.1G 15% / tmpfs 998M 0 998M 0% /dev/shm tmpfs 998M 3.1M 995M 1% /run tmpfs 499M 1.1M 498M 1% /run/lock tmpfs 998M 0 998M 0% /sys/fs/cgroup /dev/md127 14T 13Now i'm contemplating on what to do next... I might just do a reboot and hope for the best (as it SHOULD come up again, because there is now nothing that should prevent the mount action from failing). But then again... I have this strange feeling that it might not come up correct again :)
MaxxMark
Dec 20, 2017Luminary
Edit:
MaxxMark
Another interesting thing is that I noticed the system started mailing me multiple mails that the data partition went from "inactive to redundant" and from "redundant to inactive" a few times after eachother. This started right after I mounted the partition manually (screenshot attached).
