CharlieA_ECTP
Sep 19, 2016Aspirant
out-of-band management options for ReadyNAS
Hello, We are looking at mid-business type of readyNAS that can provide support for out-of-band management. We cannot find any documentation in the internet that can do so. We are aware that the ...
Sep 19, 2016Guru - Experienced User
You can configure the two LAN ports with different IP addresses.
The Web UI won't let you limit the use of the second LAN port to management only, and it won't let you prevent management via the first LAN port. But you can enable ssh on the NAS, and possibly configure iptables to block http access on the primary port if you wish.
Hopefully someone from Netgear - mdgm-ntgr or JennC perhaps - will connect you with Netgear Presales.
