gazzeg
Jun 21, 2014Aspirant
Passive Port Change Issue
Hi, When I try and change the passive ports on the Readynas 104 it does not allow me. It shows Red next to them. I nee to change this to include port 22021 in the range as this is what my machin...
Jun 21, 2014Guru - Experienced User
This is the FTP system settings?
In any event, mine are set to a non-standard range, so changing them works for me.
What firmware are you using?
Normally passive port ranges are set uniquely per server, so they can be forwarded through your router or firewall. So I don't get your reasoning here.
gazzeg wrote: I nee to change this to include port 22021 in the range as this is what my machines are using
