LanceWright
Oct 23, 2017Aspirant
Password reset is not working
Hello. I have a ReadyNAS 104, where none of my passwords are working. Even the master password reset. And, that one I know intimately. They are documented, but it's like the hardware has...
Sandshark
Oct 23, 2017Sensei
It sounds like you did (or the NAS somehow did by itsellf) an OS re-install. That resets the admin password to password. It also resets the network interface to use DHCP. So if you are using an IP address you "know" to be that of the NAS (but may no longer be) and not what RAIDar is telling you it is, that could cause the other issue.
The Degraded indication means you have a failed drive, and you definately need to get that replaced. Can you download logs from RAIDar (using either what you believe the admin password to be or password)?
