LanceWright
Oct 23, 2017Aspirant
Password reset is not working
Hello. I have a ReadyNAS 104, where none of my passwords are working. Even the master password reset. And, that one I know intimately. They are documented, but it's like the hardware has...
LanceWright
Oct 25, 2017Aspirant
Actually, I set up two separate mirrored arrays.
2 x 1TB drives mirrored
2 x 500GB drives mirrored
I'm still stuck wondering if this is a hardware issues as my passwords are not being accepted.
And, I know Netgear charge fees, but if I had access, I could at least determine whether it was worth paying for...
Sandshark
Oct 25, 2017Sensei
OK, good -- no data lost.
I realized that you said you do most of your access via ReadyCloud. While I don't use it myself, I think that may be the clue. I wonder if ReadyCloud will still work if your NAS is on a different sub-net from the rest of the LAN, so you didn't realize that was the case. And I know RAIDar will still find the NAS in that case, but local access (probably including getting logs from RAIDar) won't. So are your computer and the NAS on the same sub-net (same first three sets of numbers in the IP address)? The IP address of the NAS is shown in RAIDar and you can get your computer's IP address in Windows by right-clicking on Network and selecting Properties, then clicking on the Connection, then Details.
The reason they may not be the same is if you set your NAS to use a static IP and then made changes to your LAN (like a new router). An OS re-install will fix that, but I'm not sure you are ready for that until you know the extent of your other problem. If that is the case, post again and somebody can give you pointers on getting connected to the NAS directly from your computer.
- LanceWrightOct 25, 2017Aspirant
I'm running dynamic IPs on the Intranet, and uskng a Mac, I'll have to review to see where the NAS in living now.
But, would the OS kill the password access?
If I had access, I know I could work this out.
- StephenBOct 25, 2017Guru - Experienced User
It could of course, since it is the OS that does the logon authentication. It could also be a GUI issue - something might be messed up in the web server that is trying to apply the settings.
How familiar are you with linux?
I can stumble through updating via Linux, but here's the NUMBER ONE reason I believe I have a hardware issue:
Using RAIDar, I am provided with FOUR drives.
Only two are mounted.
WTH?!
Did I miss a class? LOL
Four drives, but only two RAID-1 mirrored volumes. Volumes are what are mounted on the network. Class dismissed.
If you still have hardware warranty coverage (3 years for the original purchaser) you can contact support at my.netgear.com. If you are correct, they will send you a new unit free of charge. If you aren't correct (my bet is on that), then you'd need to pay.
If you don't have hardware warranty coverage, then you better hope it's software.
- SandsharkOct 25, 2017Sensei
I think he means he removed two of the drives (that made up one volume), but the NAS still shows 4.
If that's the case, the NAS still knows of the existence of the other volume, even though the drives are missing, because you just yanked them out instead of dismounting them (you couldn't, since you can't get into the GUI). If you were able to get into the GUI, it would show that volume as "unknown". It's actually a bad idea to just yank out a volume, but it will typically re-mount OK. You may need to go and re-apply attributes to the shares it contains once it's re-mounted, though.
