roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mnc042
Sep 06, 2009Aspirant
roadfun wrote: Just had my first failure of this kind on my main Snow Leopard machine. So the problem is still there.
Same problem here!
It happens seemingly randomly, but then when Time Machine goes to try again, it succeeds.
If I try to manually run a Time Machine backup, the volume mounts fine.
Can't quite make it happen manually but it happens randomly on ALL my macs eventually during the course of a day.
Anyone have any suggestions/ideas? Backups that give errors tend to make me nervous. :-)
Thanks!
- Oct 20, 2020Retired_Member
