roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
jwarthman1
Sep 17, 2009Aspirant
I am having exactly the same issue. I don't change anything, don't re-enter username or password. Next time Time Machine tries, it works normally.
Has anyone discovered a root cause? It could be a Time Machine bug, or some problem with the ReadyNAS.
Thanks!
Thanks!
- Oct 20, 2020Retired_Member
