roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
bzech
Oct 14, 2009Aspirant
Hi,
I have the same TM problems on my MacPro (Mac OS X 10.5.8, ReadyNAS Duo with firmware 4.1.6). Most of the time I see error 19 in the system.log of the Mac, e.g.:
Sometimes it is error 29:
Boris
Sep 29 18:47:00 BigSwamp /System/Library/CoreServices/backupd[3448]: Backup requested by user
Sep 29 18:47:00 BigSwamp /System/Library/CoreServices/backupd[3448]: Starting standard backup
Sep 29 18:47:02 BigSwamp /System/Library/CoreServices/backupd[3448]: FSMountServerVolumeSync failed with error: -36 for url: afp://[email protected]/ReadyNAS
Sep 29 18:47:07 BigSwamp /System/Library/CoreServices/backupd[3448]: Backup failed with error: 19
Oct 10 15:04:26 BigSwamp /System/Library/CoreServices/backupd[4169]: FSMountServerVolumeSync failed with error: -6600 for url: afp://[email protected]/ReadyNAS
Oct 10 15:04:26 BigSwamp /System/Library/CoreServices/backupd[4169]: Authentication error - the correct user or password info may not exist in the System.keychain or the server may no longer allow access for this user.
Oct 10 15:04:31: --- last message repeated 1 time ---
Oct 10 15:04:31 BigSwamp /System/Library/CoreServices/backupd[4169]: Backup failed with error: 29
Boris
- Oct 20, 2020Retired_Member
