roadfun
Aug 16, 2009Aspirant
Periodic (daily) Time Machine failures
I am running TM on an iMac with 10.5.8 to a Duo running 4.1.6. However I am getting a failure about once a day where TM pops up a dialog saying the network volume could not be mounted because of a pro...
mnc042
Oct 15, 2009Aspirant
Skywalker wrote: It's hard to say. It may be worth a try to disable guest access on all the shares to see if that makes a difference. It's a bit of a wild guess, but I've been thinking there's a chance that OSX may be getting confused if it connected to the box last using the guest UAM.
My other hunch, in your case, is a possible Bonjour discovery issue. We noticed in your logs a lot of bad packet errors, so perhaps it's just a network issue for a brief time when OSX is trying to look up the NAS via Bonjour. Are both systems on the same switch? If not, would it be possible to move them to the same switch for a while just as a test?
They are not, in fact, on the same switch -- but it would be easy to move them to the same switch.
I'll give that a try. If that doesn't help, I'll try removing the AFP guest access.
Could the bad packet errors be something wrong with the NAS itself? Perhaps the network interface going bad?
- Oct 20, 2020Retired_Member
